hey my car wont crank over.. i dont think its my battery because all my music and lights are still on.. neways i can push start it and it starts right up.. i went to go try the screwdriver on the solinoid and it sparked a tiny bit but no start!! so should i try replacing the solinoid?? this same problem happened a while ago and it was somthing with the clutch saftey switch.. but i remember i could still start it by the screwdriver on the solinoid so i dont think its the saftey switch.. but correct me if im wrong.. any help is appreciated
Repostyle
sounds like the starter to me.
When you turn the key (or jump with a screwdriver) do you hear the solinoid click? If it clicks, it's the starter.
Bladez5_0
I'd check the battery. If you jumper the solenoid and it doesn't do anything then it sounds like the battery to me or the starter as Repostyle stated.
If you have the car in neutral, ebrake applied and all other safety precautions performed, and it wont start with a screwdriver across the two big lugs on the solenoid, it is not the solenoid.
That test bypasses the solenoid. I would look at the battery, its connections, the motor ground and even the starter cable.
It takes a lot of amps to crank the motor, but very little to run your stereo, so that is not the greatest test.
Good luck.
Good luck.
well i took the starter off and went to autozone and got it tested.. it came out to be good.. so i went home and put it back on..and gave her a shot and she started right up??the only thing i noticed was the ground cable on the starter was kinda loose.. still touching and all but just kinda loose.. could that have been the reason?? i really dont want to get stuck newhere again
A good ground is a must have for the starter to work. You can have 1000 amps available power on the positive side of the battery, but none of it will be useable if you don't have a good ground.jstang209 said:well i took the starter off and went to autozone and got it tested.. it came out to be good.. so i went home and put it back on..and gave her a shot and she started right up??the only thing i noticed was the ground cable on the starter was kinda loose.. still touching and all but just kinda loose.. could that have been the reason?? i really dont want to get stuck newhere again
