Bad Starter
  • Thread starter Thread starter 7upstang91
  • Start date Start date Nov 30, 2009
7upstang91
936
124
74
Florida
Nov 30, 2009
  • Nov 30, 2009
I have had my starter for a year and a half. The car is now having a hard time starting when its warm. Starter or something else? It starts fine when its cold. the warm start keeps getting worse and worse, it almost didn't start last time.
skunk21
1,203
Taxachusetts
Nov 30, 2009
  • Nov 30, 2009
heat soak. do you have a mini starter? what headers you have? might have to wrap it to shield it from the heat .some people have really good luck and have no heat related issues and some fight it all the time luck of the draw I guess. also check the condition of the main starter wire but I'm pretty sure she is heat soaked.
7upstang91
936
124
74
Florida
Nov 30, 2009
  • Nov 30, 2009
Wrap the headers or starter itself. The starter is a replacement from Advacne Auto. They are ceramic BBK shortys.
Thanks for the help!
7upstang91
936
124
74
Florida
Dec 1, 2009
  • Dec 1, 2009
If the starter is heat soaked it should fail the test at Advance Auto.
skunk21
1,203
Taxachusetts
Dec 1, 2009
  • Dec 1, 2009
wrap the starter itself. you might want to try a mini starter if this keeps up. they way you described the problem it's heat soaked and will soon be on it's way out.
7upstang91
936
124
74
Florida
Dec 1, 2009
  • Dec 1, 2009
I took it out and had it tested. The starter is fine. But the top bolt wasnt tightened all the way. Could this be a warm start issue?
skunk21
1,203
Taxachusetts
Dec 1, 2009
  • Dec 1, 2009
no that wasn't the problem and it will no doubt test fine because it is still good. heat soak is a constant heating and cooling cycle that the starter goes through and wears it out eventually. They make wrap, boxes, etc. for this problem. Ford also has a mini starter and another good one is the one from PA performance. If you google starter heat soak you will see tons of topics related to this. Fords, GM's, VW's, etc of various modles have issues. The main cure for our cars is wrap or a mini starter.
I went through this myself this summer and checked my block ground and it was fine, then repalced the main starter cable since it was 18yrs old anyways and still did it. I got the pa perf. mini starter sitting in a box waiting to go in because by the end of the summer after a long drive if I had to stop it crank over so hard I didn't think it would start, the next morning first click started no problem. good thing it wasn't a daily driver. best of luck and make sure to check you starter bolts
7upstang91
936
124
74
Florida
Dec 1, 2009
  • Dec 1, 2009
Allright thanks man!!!! I just ordered the Summit one for $17. Good enough? Said to reflect 90% of heat.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
N
Sticky Throttle
  • NooStang
  • Jun 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
General karthief
