Bad throttle response need help please
Recenlty added a cam , new heads , 1.6 roller rockers 80mm MAF, and 70mm throttlebody cleaned the TPS had car run on the dyno and it read that the car was running good, but it was basicly undrivable it bucked really hard if not excelerating bumping up the fuel presure to 40 helped alot for that but still have poor throttle responce. i am checking the vacume lines again and replaced the PVC , filter and gorrmet. still not working correcy so im rechecking everything.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
