  • SN95 4.6L Mustang Tech
Bad timing...Er something
  • Thread starter Thread starter UptownGambler1
  • Start date Start date Dec 2, 2004
U
UptownGambler1
  • Dec 2, 2004
Hey, if anyone has any good suggestions...
A couple months back, my 99' GT started acting up. After driving for a while, I tried to pass someone, but when I hit the accelerator the engine fell on its face. It sounded like an old car with timing and distributor problems. The engine wouldn't quickly build RPM, but instead stuttered badly with strong acceleration. I could build RPM slowly, but not past about 4000. I pulled over, and could not repeat the problem in park or neutral (Auto Tranny). I tried to figure out the problem, but check engine light never came on and a scanner didn't pull any codes. I had the problem a couple more times after LONG DRIVES and mainly in HOT conditions, but couldn't figure it out , and it went away
TODAY IT CAME BACK. I thought I could buy some time to try and figure it out through the winter (with cool conditions), but it happened again today after short driving. I figure something is heating up and malfunctioning, but what? At none of these times was the car overheating or at above normal temps (temp at about half way on the gauge).
Any suggestions?
M
moreause
74
  • Dec 2, 2004
Any suggestions?
did you advance you timing...if you did maybe you could check were you fueled up when the probleme occured
if not when the cat a clogged it tend to do as you said but it is hard to find
i read about a guys after triing every thing on is card just held the pedals to the floor for a minute or two and finally the cat cought in fire...
U
UptownGambler1
  • Dec 2, 2004
I haven't done anything to the timing yet. Everything is stock except magnaflow weld-ins. The car had plenty of gas when it was happening.
Don't think the cat would do it since it only (except today) happens when the car has been driven for a long time (60-70+ miles).
twogts4us
4,188
12
79
Dunedin, FL
Dec 2, 2004
  • Dec 2, 2004
Fuel filter....
daver01
396
Lexington, Ky
Dec 2, 2004
  • Dec 2, 2004
sounds like what happens to me every time i forget to turn traction control off? the little green wheel of death.
Venom_Nitrous
416
Spearfish, SD
Dec 3, 2004
  • Dec 3, 2004
I always thought it was green snail.
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
M
Kind of a unique problem
  • MadMatt7
  • Oct 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 15, 2026
rednotch
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
