Im getting a vibration in the trans tunnel area and it starts at about 75mph and gets really bad above that (feel it in the trans tunnel and shifter). I know ist not rpm reated as it onl happens at this speedand above. Shifted from 5th gear, 4th gear, neutral, and at this speed and it does not change the vibration. I have since replaced the axels and a rear wheel (curbing incedent) and everything in the pumpkin looks fine. So unless I missed anything, its gotta be the output saft on the tranny or the DS. I checked the u joints on the DS and they seem fine (I didnt remove DS from car, jus wiggled it) and I feel 2 weights on it and cannt find a weld where a weight might be missing. This is a FMS alum. piece. Anyone have any ideas? Also this happend on the highway at 150+ mph. Everything was fine and then I heard a clunk underneath and things started rattling like crazy. I immediately pulled it down to about 55mph and it was fine again. But since then I cant get it over 80 without the bad vibes. Any thoughts? -Robin
). And no it wasnt a missing wheel weight. Well, I did throw some wights on a wheel (first thing I checked) and had it rebalanced and checked the other wheels however that made no differece in this problem.
