Guys what are the symptoms of a harmonic balancer that has slipped on it's outer ring? I am trying to find the best timing for my 302 and I can't get the engine to ping at all lol!
What a good load to get the engine to ping under...? Another question would be when I put the spout connector back in, will the timing marks be readable with a timing light?
When mine went bad it caused a huge vibration and when it sliped off the hub the engine could not be ran without it jumping around in the engine compartment. It caused a motor mount to break.
I mean can you take the belt off and wiggle the outer ring around to see if it's bad? What is a good load though to put the engine under to ping besides driving up a hill. Can you power brake the truck would that work?
like when the motor need to pull hard at lower rmps. say like in 5th gear doing 40mph and pushing hard on the gas pedal to make it pick up speed, is an example.
as soon as you plug the spout back in the computer takes over on the timing.
