Balancing/Flywheel questions?
  • Thread starter Thread starter ninety15.0
  • Start date Start date Feb 28, 2006
ninety15.0
1,336
  • Feb 28, 2006
Hey guys whats up? Im going to be installing my spec stage II on saturday and i have a couple questions bout my flywheel. I have a stocker but when i built my motor i had the whole rotating assembly balanced including everything from the crank pulley back to the flywheel. I only have use of the lift for a day and i need to get the flywheel resurfaced and everything installed again in less than a day. I have access to another stock flywheel and im wondering if i just get that one resurfaced ahead of time and use that in place of mine will i run into any problems with it being different from the flywheel the motor was balanced with? i kinda doubt it will be a problem...but i wanted to check first. thanks in advance
-Nick
M
matm347
2,056
  • Feb 28, 2006
Using the flywheel that was balanced with your other stuff would be best, but no..not absolutely necessary.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
L
2006 mustang gt has high clutch bite
  • leevikisley
  • Feb 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Feb 22, 2026
leevikisley
L
J
Resolved Ford 302 damper issue
  • James S
  • Aug 8, 2026
  • Other Auto Tech
Other Auto Tech Aug 8, 2026
James S
J
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
