Balancing/Flywheel questions?
ninety15.0
1,336
Hey guys whats up? Im going to be installing my spec stage II on saturday and i have a couple questions bout my flywheel. I have a stocker but when i built my motor i had the whole rotating assembly balanced including everything from the crank pulley back to the flywheel. I only have use of the lift for a day and i need to get the flywheel resurfaced and everything installed again in less than a day. I have access to another stock flywheel and im wondering if i just get that one resurfaced ahead of time and use that in place of mine will i run into any problems with it being different from the flywheel the motor was balanced with? i kinda doubt it will be a problem...but i wanted to check first. thanks in advance
-Nick
