  • 2.3L (N/A & Turbo) Tech
Ball joint?
  • Thread starter Thread starter Keasbey
  • Start date Start date Jun 3, 2005
Keasbey
915
Montreal
Jun 3, 2005
  • Jun 3, 2005
Is there another reason why my front tires are gettin worn only from the inside? could a bad suspension can do this? I know that my ball joint are a bit used, because there is a little play when I'm trying to move them (in&out), but not totally worn out..
Can we only change the balljoint? or we have to change all the control arm?(hope not).
The car have 180k KM (so approx. 115k miles)
so what do you think?
R
RustBucket
585
Buford, GA
Jun 3, 2005
  • Jun 3, 2005
My left front tire is doing the same thing. You can purchase a ball joint without the control arm from your local parts store, but looking at the control arm, my guess is that you would have to have the old joint pressed out and the new joint pressed in.
Stinger
7,754
24
118
Basehor (Kansas City), KS
Jun 5, 2005
  • Jun 5, 2005
You simply have what is referred to as "toe out". In other words, your front end needs aligned.
mr_woodster
1,314
Riverside, CA
Jun 6, 2005
  • Jun 6, 2005
And yes, you have to have a tool that allows you to press it out, if you'd like to change your ball joint.
Dont forget to lube it.
BELL
722
California
Jun 6, 2005
  • Jun 6, 2005
get an alignment first before you start throwing parts at it... thats my opinion...
P
Suspension Different height ball joints?
  • pindude80
  • Jun 10, 2024
3K
Fox 5.0 Mustang Tech Jun 12, 2024
limp
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 14, 2026
joeybuddy96
J
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
W
Megasquirt base tune for 94 5.0
  • wrx757
  • Mar 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 6, 2026
wrx757
W
