BAP Sensor Question
  • Thread starter Thread starter n2o-89fox
  • Start date Start date Dec 23, 2007
N
n2o-89fox
116
ca
Dec 23, 2007
  • Dec 23, 2007
Ok I have been chasing this slight hesitation ever since I bought the car. It does it only once every time the car is started then runs great after the little hesitation. Now everything on the topend it brand new from chasing this but now it has been brought to my attention that we are supposed to have a map/bap sensor. The guy before me deleted all kinds of stuff without know what it was or did. So I need to see if anyone has a pic of the bap sensor hooked up so I know where to look for it. I have a whole bunch of electrical connectors that are unplugged on the passenger side and one looks like it could be for the bap sensor, so if someone could tell me what color the wires are going to the sensor so I can verify that it is the connector for the bap.
Thanks for your replies!
87foxstang
Cromwell, CT
Dec 23, 2007
  • Dec 23, 2007
http://fordfuelinjection.com/images/map.jpg
heres a MAP sensor, it should be located on the firewall. My car ran pig rich with this unplugged and the throttle response was garbage. Its late now, so thats the best I can do for a picture. Ill get a picture of mine plugged in tomorrow.
N
n2o-89fox
116
ca
Dec 23, 2007
  • Dec 23, 2007
hmm... I dont see it anywhere on the firewall. does the connector have 3 wires or 2? and are the colors 2 pink 1 green or 1 green and 1red/brown? wire is dirty cant tell if it is red or brown. Thanks
HISSIN50
34
129
Dec 23, 2007
  • Dec 23, 2007
For wire color help, the year of your stang is helpful.
If an early aero fox, this diagram might help. Look at the top of the diagram, just right of center. The connection is at Pins 45, 46 and 26.
N
n2o-89fox
116
ca
Dec 23, 2007
  • Dec 23, 2007
its an 89, thanks for the picture and the diagram.I found it the guy before me relocated it to the driverside wheelwell.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 24, 2007
  • Dec 24, 2007
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
89 through 95 cars have a working Check Engine light. Watch it instead of a test lamp.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
