Batterie light
The majority of vehicles that come into work with a battery light on would be the alternator going bad cause it is not putting out proper voltage.
The only vehicles I've seen where the battery light may come on on when the battery is bad has been any dodge/chrysler 01-05.
Start your car and us a multimeter on your alt. ground to the alt it self and lift the rubber cover off the nut and touch that see if it is putting out 13+ volts. High voltage is bad too, means a bad regulator. If that goes it can run up to 110 volts :p
