  • 1994 - 1995 Specific Tech
Battery cables
  • Thread starter Thread starter kiNe5
  • Start date Start date Nov 5, 2004
K
kiNe5
18
  • Nov 5, 2004
how long do battery cables have to be to replace it the whole way for both. (94 gt)
mystang94gt
951
Bay Area, CA
Nov 5, 2004
  • Nov 5, 2004
Well really your best off buying the entire assembly from 50resto or even from ford direct. I replaced mine recently and it seemed as though there were nearly 20 sensors (not quite but seemed like it) and plugs that are attached to the cables. Its one big assembly with pos, neg, starter, 02 sensors, oil pan sensor, ect ect ect. There is so much stuff attached to it, that it would be way too much work trying to splice everything. But they cost a pretty penny. I paid right around 2 bills for the whole thing. And be prepared to be pissed off while installing. Some of the bolts that hold the cables in place are a PITA to get a wrench or socket on. good luck.
K
kiNe5
18
  • Nov 5, 2004
wow that sucks. thanks
blackmagic94
1,215
Tucson, Arizona
Nov 6, 2004
  • Nov 6, 2004
The battery cable harness only connects the following
Power to starter
Signal to starter
Battery to ground
The oxygen sensor harness is attached but can be removed seperate
I replaced my harness with 20 bucks worth of cables from a parts store.
The main harness and the power harness are not the same.
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
R
WTB/Trade WTB: Throttle Cable
  • Randy Orton
  • Jun 30, 2026
  • Engine and Power Adder
Engine and Power Adder Jun 30, 2026
Randy Orton
R
F
Pcm ground connector
  • fox1990
  • Jan 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 12, 2026
Mustang5L5
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
