battery draining
swt89pony
N. Aurora IL
I have an '89 gt. the problem I am having is that something is draining the battery when the car is off. It has new battery, alt, starter, and selaniod. How can I find out what is causing the battery to drain. I have looked over the wires, and can't seem to find anthing out of place. What can I do? This problem is driving me crazy, and I don't want to pay a **** ton of money for someone to look at it, and it be something simple. Please help.:
I had the same problem, i found the light was on in the sun visor, but i could only see it at nite when it was dark.. i left both doors closed and looked in. turns out the pad that held the pin in to shut the light off was no good.. i used a penny as a temp. fix till i got new visors.. hope that helps....
Along the lines of what 86 said, I'd disconnect a battery terminal. Put your meter in series inbetween the battery post and terminal, set the meter to measure amperage draw and pull fuses until the reading drops a bit.
Here is a handy link from Saleen0679.
The source of his post (with an additional link) is here.
Good luck.
you might want to try the circuit breaker for the power windows. its under the under the hood on the soleniod.mine kept draining my battery and come to find out the breaker was going bad.
I charged the battery, then pulled all the fuses and it is still dropping very slow.
What did the testing show? What was the current draw reading?
Knowing that is key because you can have a failing battery that will not hold a charge, even though there is not an issue with excessive parasitic draw.
Good luck.
