Battery Light Came ON
  • Thread starter Thread starter TheSlowLX
  • Start date Start date Sep 24, 2005
T
TheSlowLX
44
  • Sep 24, 2005
Ok so I just finished hidding all the wires through both the passenger and driver side of my car. I hook everything up and start the car. Car starts fine but the light with the battery sign came on. I leave the car on and disconnect the ground off the battery. Car Dies. Now I know the alternator was perfectly working BEFORE I messed with the wires. Could I have blown a fusible link that runs fron the alt to the solenoid? If i did how do i go about changing it? any pics would help. thanks.
D
Daggar
3,902
  • Sep 24, 2005
It may just be that something didn't get reconnected or that it came loose while moving stuff around. Check the stator wire for the alt and make sure it's getting juice.
HISSIN50
34
129
Sep 24, 2005
  • Sep 24, 2005
Yep. First off, I would NOT do the disco' test that you did - the resulting voltage spike from the alt can harm computer components. Future reference (and when people search and see that someone did that, they think it is ok to do, which it is not on an EFI car, IMHO).
Do you have a 3G alt (I saw dual fans which made me wonder).
I would make sure the switch-and-sense wire is still attached to the solenoid-side wiring of the alternator cable. And accordingly, if you did anything with the stock voltmeter gauge, that wire needs to be connected for the switch-and-sense to work.
I still think Daggs is right on - just cruise over what you did and you should see something.
BTW, there is a fusible link on the alt cable, but when you did your test, had you blown that, I dont see how the car would get juice to keep running (with no alt input, in essence, with no alternator power to the electrical system).
Good luck.
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
