battery light when rpm's hit 4k
So i have posted this issue before i.e. right around 3.8k-4k, voltage drops and battery light comes on, flickers, then goes away after that rpm range.
Thought i had fixed problem when i bought a quality PA Performance alternator (after i thought the remanuf one i bought that lasted 6 months prior was no good), however issue is still there.
I have heard that if my problem exists as it does, it could be the voltage regulator on the alternator. I am beginning to think its NOT the regulator and something else with my car that is causing these regulators to short as i couldnt have got 2 badd alternators.
what could be other possiblities non alternator related that could cause this issue on my car?
thanks in advance
The voltage regulator is inside your alternator and is not user servicable. Typically the whole alternator is replaced. The odds are small but maybe you did get a bad 2nd alternator.
Pull yours off and take it to get bench tested at a parts house.
If the alternator output voltage briefly becomes too high, the internal regulator will turn on the lamp and shut down the alternator until the voltage drops to a safe value. You could monitor your alternator + terminal with a meter to see if the voltage rises above 16V as you increase engine RPM. Be careful and wear eye protection. If yes, some likely causes are poor battery connections, a damaged wire between alternator and battery, or a battery with a high internal resistance (this condition can be intermittent, and often worse in cold weather).
