battery relocation
  • Thread starter Thread starter slow93
  • Start date Start date Dec 12, 2005
slow93
406
  • Dec 12, 2005
where is the best place to hook up the ground wire in a hatch?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 12, 2005
  • Dec 12, 2005
Rear mounted battery ground wiring. Follow this plan and you will have zero ground problems.
One 1 gauge or 1/0 gauge wire from battery negative post to a clean shiny spot on the chassis near the battery. Use a 5/16” bolt and bolt it down to make the rear ground. Use a 1 gauge or 1/0 gauge wire from the rear ground bolt to a clean shiny spot on the block.
One 4 gauge wire from the block where you connected the battery ground wire to the chassis ground where the battery was mounted up front. Use a 5/16” bolt and bolt down the 4 gauge engine to chassis ground, make sure that it the metal around the bolt is clean & shiny. This is the alternator power ground.
Crimp or even better, solder the lugs on the all the wire. The local auto stereo shop will have them if the auto parts store doesn't. Use some heat shrink tubing to cover the lugs and make things look nice.
The computer has a dedicated power ground wire with a cylindrical quick connect (about 2 ½”long by 1” diameter. It comes out of the wiring harness near the ignition coil & starter solenoid (or relay). Be sure to bolt it to the chassis ground in the same place as you bolted the alternator power ground. This is an absolute don’t overlook it item for EFI cars
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
Rear mounted battery distribution blocks?
  • 387lx
  • Mar 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
JD1964
Electrical Starter solenoid green wire?
  • 387lx
  • Jun 1, 2026
Fox 5.0 Mustang Tech Jun 2, 2026
AeroCoupe
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
