  • 1994 - 1995 Specific Tech
battery terminals
  • Thread starter Thread starter 96darkhorse
  • Start date Start date Jun 12, 2006
9
96darkhorse
693
wilmington, california
Jun 12, 2006
  • Jun 12, 2006
hey guys
i was wondering if any of you guys are running aftermarket battery terminals...im having trouble keeping my stockers clean.....im always cleaining off the acid that builds up on them and their looking pretty beat up....anybody have any suggestions?
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Jun 12, 2006
  • Jun 12, 2006
I dunno what one's to recommend. Just don't replace them with the hoop style (like factory). I made that mistake & I hate them.
Also, check your terminal wires while you have them off. The wires can get corroded all the way down. If they are, they really need to be replaced. And get some of that anti-corrosion spray from the parts store (few bux).
Koniz
137
Geneseo, IL
Jun 12, 2006
  • Jun 12, 2006
just get those red and green rings that you see in the battery section at the parts store I have used them for 3 years on all my cars and I dont have any corrosion or acid on my batteries or terminals
95strokerPSU
986
Sacramento from Philly
Jun 12, 2006
  • Jun 12, 2006
Wouldn't build up mostly be due to the battery? What kind of battery do you have? I've had my Optima for two years and theres not even a spec of build up on it.
But clean the terminals and posts with water and baking soda.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jun 12, 2006
  • Jun 12, 2006
Build-up is usually caused from the different metals being in contact with each other. Corrosion is inevitable, at some stage or another. A lead acid battery has lead plates and the two battery terminals are lead. This should be obvious because the terminals are very soft. With steel or brass terminals, electrolysis occurs and corrosion is it's by-product.
Another is caused from acid fumes from over charging. Lead-acid batteries vent hydrogen gas, which is the reason for the vent caps. But sometimes, fumes from the acid mixture can vent past the caps, and find it's way to the terminals.
And the reason your Optima battery doesn't corrode is because it's not a lead-acid battery.
Clean the terminals on the battery and connectors with a terminal cleaner tool (2-3 bucks at autozone), reinstall the connectors and spray the preventive spray. It helps.
Scott
9
96darkhorse
693
Jun 13, 2006
  • Jun 13, 2006
well i cleaned them up and greased them up and their are good to go: thanks guys
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
Big Posi and Neg wire from Starter to Battery and Alt wires..........
  • from6to8
  • Feb 9, 2026
1994 - 1995 Specific Tech Feb 9, 2026
AeroCoupe
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
