battery tie down..
  • Thread starter Thread starter Georgie
  • Start date Start date Aug 28, 2006
Georgie
455
Montreal, Canada
Aug 28, 2006
  • Aug 28, 2006
anyone know a better than stock battery tie down kit??? i just orderd an optima...
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
  • Aug 28, 2006
http://cgi.ebay.com/ebaymotors/Ford...tegoryZ33575QQihZ013QQitemZ230021318821QQrdZ1
Sicarius428
2,085
Aug 28, 2006
  • Aug 28, 2006
Check ebay. I got a holdown for mine there and just drilled a couple holes in the inner fender and fabbed up an aluminium L bracket which uses the power steering bolt hole to mount to.
Kevin
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Aug 28, 2006
  • Aug 28, 2006
You can always use this as an excuse to relocate you battery to the trunk..
XavB
74
Honolulu, HI
Aug 28, 2006
  • Aug 28, 2006
Wow those battery hold downs are pretty nice. I was wondering where I could get a battery hold down too. I just put in a Yellow Top Optima but the stock hold down isn't holding the battery. I guess that might justify spending the money.
Saleen0679
876
24
49
Yakima, WA
Aug 28, 2006
  • Aug 28, 2006
When using an Optima battery in a Fox body you will need to get the hold down adapter in order for the stock battery wedge to securely mount the battery. Optima used to send them out free of charge, or maybe an Optima dealer carries them.
XavB
74
Honolulu, HI
Aug 28, 2006
  • Aug 28, 2006
HAHAHA....I read your post and then I looked in the top that I took off the battery and the tie down adapters were all in there. DUH I guess I should have looked in there. thanks.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
