I think I may have found what's causing my electrical problem. I had the hood up and as I turned the key, the car would NOT start. But, I also saw smoke coming from the battery area. The small wire next to the larger wire going to the negative post was smoking from the pigtail. The other end was grounded and tight going to the chassis.
Can I remove the pigtail and have the small wire go directly to the negative terminal?
The battery I got yesterday (brand new 1000 cranking amps) is dead.
I'm charging the battery and will wait for a reply.
Also, anybody know the length of the battery cable that goes from the starter to the negative terminal? If I can get to it, I may replace the whole cable instead of just replacing the battery terminal.
Thanks in advance.
Larry (91 LX 5.0 Convertible)
Thanks in advance.
