BBK adjustable fuel pressure regulator
  • Thread starter Thread starter stevesLX
  • Start date Start date Apr 1, 2007
stevesLX
373
cincinnati
Apr 1, 2007
  • Apr 1, 2007
I went out and bought a BBK AFPR and the instructions say to disconnect the vacum line from it and plug it and adjust the fuel pressure. Well I did that and when I hook the vacum line back up the pressure drops. For instance I set it around 35 with the vacum line disconnected and when I stuck the line back on it drops the needle on my pressure guage down to around 29 - 30. Is that what is suppose to happen or what. Something else I noticed is if I rev it up the pressure goes up initially and then it goes down to around 25 or so and stays there until I let off the throttle cable. I have 24 # injectors. I am not really sure where I should have the pressure set but I am curious about the whole vacum line deal and whats right and wrong.
jtfairlane
468
  • Apr 1, 2007
The pressure is supposed to drop when you reconnect the vacuum line, that's why they have you take it off in the first place for setting the pressure with a gauge.
HISSIN50
34
129
Apr 1, 2007
  • Apr 1, 2007
The pressure drop into the 20's should only last a second. If it lasts longer, that indicates an issue.
Good luck.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Fuel Bad regulator diaphragm?
  • JD1964
  • May 20, 2025
2K
Fox 5.0 Mustang Tech Jul 16, 2025
JD1964
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
