  • 1994 - 1995 Specific Tech
BBK Long tube header install problem
  • Thread starter Thread starter drewlash
  • Start date Start date Jul 16, 2004
D
drewlash
  • Jul 16, 2004
I have a 95 gt convertible. I am working on replacing the headers with BBK long tubes. I got both headers into the general area fine, and the passenger side header bolted. The problem is with the driver side header. It is hitting the convertible support bar. If I raise the engine, it will clear that bar and allow me to bolt it on, but then the header will support the engine.
Right now I have the support bar loosened so that I could bolt up the header.
My only ideas right now would be to dent the header a little to allow clearance or to cut a little groove out of the support bar to give it the clearance it needs.
That is a quick drawing of it. The circle is where the header and support hit. Most of the supports strenth appears to be from the basic X type structure.
What would be the best way to get the header in?
Thanks,
Andrew Lash
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Jul 16, 2004
  • Jul 16, 2004
i have no idea what your talking about but thats a cute drawing ttt for you.
94TURBO5 O
2,509
VA
Jul 16, 2004
  • Jul 16, 2004
Man I have a vert and I am going to do this install in a few weeks and have been reading up on a lot of installs and this is the first I have heard of this. Let us know what you figure out.
H
hbk_136
194
Southeastern GA
Jul 16, 2004
  • Jul 16, 2004
I am in the EXACT same boat. I have a 95 GT vert, and i will be installing my LT's in a day or so. I will most likely run into this problem myself. Someone help us please!!
xYoung347x
382
  • Jul 17, 2004
well I have my long tubes on my 94 convertible but Im not telling.. Its so easy to figure it out. I will give a hint, cuss a lot then you'll figure it out.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 17, 2004
  • Jul 17, 2004
Oh man, you are soooooo mean!!!!!!!
The box in the middle is the square section that sits underneath the oil pan, which has a hold in the square so the oil will drain through it. The 4 bars extend outwards, just like the drawing shows. I don't know what the heck to call this thing. I guess you would call it a subframe?
I assume from the drawing that the header is going to hit one of the side bars.
Everyone said that to install the LT's, you will need to disconnect the motor mounts & jack the motor up a few inches. This will allow the header to be installed. Then slowly lower the motor & make sure it won't hit the bar.
It shouldn't hit the bar. It may look that way, but once you finish it, everything should fit fine.
These LT's are for a 94-95 GT Vert, right? If not, you will definately have some fitment issues that will require welding/sawzalling <--
Scott
D
drewlash
  • Jul 17, 2004
I had to raise the engine to get the headers on there. The problem is that when I lower the engine, the header will be resting on top of the support beam and will just hold the engine up. I've tried everything I can think of to get the header around that beam.
And these headers are for 94-95 mustangs. I have never seen any headers made specifically for a vert.
If anyone knows how to get the header to fit around that support, please help me.
Thanks,
Andrew Lash
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Jul 17, 2004
  • Jul 17, 2004
I have talked to several people who couldn't get BBK longtubes to fit on a vert, because of exactly the problem you are describing. So it may be that mere cussing will not solve your problem -- may have to go with a different brand of longtubes.
Dave
DJHA90
581
Texas
Jul 17, 2004
  • Jul 17, 2004
I had to take off the x brace, cut the brace, that was in the way, off -- and then weld it back on a little farther toward the middle.
YEAHLOH95
1,249
EVERETT,PA
Jul 17, 2004
#10
  • Jul 17, 2004
  • #10
i may not have a vert but i have those headers just tkae the brace off and clearance it to fit around the header that brace can't do that much
xYoung347x
382
#11
  • Jul 17, 2004
  • #11
okay the way I did it is I cut that bar going across and weld it up a little more. Problem solve! I also hammer some stuff down too, so good luck.
Black Stampede
1,811
Grand Rapids, MI
Jul 18, 2004
#12
  • Jul 18, 2004
  • #12
I have BBK LTs on my '95 vert and found the easiest solution. Take the stupid thing off and leave it off. You will not notice a difference.
Good luck.
GTPhreak
5,505
Rowlett, TEXAS
Jul 18, 2004
#13
  • Jul 18, 2004
  • #13
just take the brace off
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
BBK 351w headers
  • fully
  • Jan 30, 2025
1994 - 1995 Specific Tech Apr 4, 2025
dcm0123
D
For Sale BBK 1-3/4" long tubes
  • Kid wita 5oh
  • Dec 4, 2025
  • Exhaust Parts
Exhaust Parts Dec 4, 2025
Kid wita 5oh
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
