  • 1994 - 1995 Specific Tech
Bearing Retainer Installation
  • Thread starter Thread starter 95BlackTan50
  • Start date Start date Nov 30, 2005
95BlackTan50
116
  • Nov 30, 2005
I'm waiting on my T5 that I'm getting from a salvage yard to be rebuilt so I can do my AODE to T5 swap. I've read in many posts that if the Bearing Retainer is aluminum, it should be swapped with a steel one. A couple of questions:
1) If the tranny is a 94/95, should the Bearing Retainer already be steel? I've read that it should be steel.
2) If the Bearing Retainer is aluminum, how hard is it to replace? I've downloaded a T5 rebuild document that talks about pressing in a new oil seal and performing a preload shimming operation. If I have an assembled one, can I just unbolt the old one and bolt on the new one using RTV?
3) If things change and I end up using a pre-94 T5, is the bearing retainer a different size than the 94/95?
Thanks
94gts
873
Carmel, New York
Nov 30, 2005
  • Nov 30, 2005
yes the fox t-5 has a different bearing retainer than us. Our input shaft is longer too. The aftermarket ones have a steel shaft that the tob slides on and an aluminum base. I bought a retainer to rebuild my t-5 with but i am going to ditch my t-5 for a tko. I sell it to ya cheap if you want
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
R
Drivetrain Clutch
  • Robman8028
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jul 2, 2025
AeroCoupe
