  • SN95 4.6L Mustang Tech
bearing troubles? testing?
  • Thread starter Thread starter 98stanggt22
  • Start date Start date Jan 1, 2013
98stanggt22
65
Illinois
Jan 1, 2013
  • Jan 1, 2013
I know how to and have already tested them and the bearing noise didn't change when pulling spark plug wires individually. how would I test my main bearings without pulling everything? is there a quick test similar to the rod bearing test? are there any other failures or causes that sounds similar? the noise speeds up as the engine does. it also sounds like its right at the crank pulley. my educated guess is the front main bearing. any input or advice. thanks
bhuff30
6,037
35
129
Olathe KS
Jan 2, 2013
  • Jan 2, 2013
Not much detail here. So what kind of noise does it make? When does it make noise. Be specific and detailed. Cold/Hot? idle/full load? high rpm/low rpms?
It is unlikely a main bearing issue. If the engine was oil starved, rod bearings will complain long before main bearings. If the engine was starved of oil, the rod bearings are likely done. Other common issues are valve train or timing chain related. Both are relatively easy to fix, at least compared to rod bearings.
trinity_gt
3,125
81
99
Canada
Jan 2, 2013
  • Jan 2, 2013
I agree with bhuff: Mains are not a common issue on these engines and oil starved rod big-end bearings are a much more common failure.
If you can provide a sound clip it would be very helpful; everything is just WAGs without something objective to go by.
You say the noise is down near the crank pulley: It's even possible the noise is related to a timing chain/guide/tensioner problem and not a bearing at all.
98stanggt22
65
Illinois
Jan 2, 2013
  • Jan 2, 2013
well could you first tell me how to upload a video?
its a constant noise no matter hot or cold it speeds up as the engine speeds up. yet when it speeds up it fades away slightly but is always there. nothing really affects the noise. at first I thought it was just a loose crank pulley. I also ran the car without the belt and the same noise and noise level. it is loud at idle especially that's why I think something is loose or worn on the inside like possibly timing chain noise idk. theres only a few things of what they are and I need to figure out how to diagnose it. I know how to fix it but I have to find what exactly it is. thanks
bhuff30
6,037
35
129
Olathe KS
Jan 2, 2013
  • Jan 2, 2013
Bearing noise will vary with load and temperature. I am thinking timing chain noise or valve train. Since you say it seems to come from the front, it is more likely the timing chain. There are some hydraulic adjusters on the chain which can fail and there are guides which can wear and cause excess slack. You'll just have to open her up and see. If I pulled the front cover, I wouldn't put it together without new guides as they tend to wear over time.
R
rockyracoon
874
27
49
margate NJ
Jan 3, 2013
  • Jan 3, 2013
If it is the guides please dont continue to drive the car as that is what destroyed my motor. The bits of plastic clogged up the screen on the pickup tube and then proceeded to starve the motor of oil pressure, not good.
98stanggt22
65
Illinois
Jan 3, 2013
  • Jan 3, 2013
it does vary a bit but it does not disappear. they have new guides. I think a failed tensioner could be the issue. how can you test the tensioner?
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
  • Gulftown980x
  • Jul 29, 2026
squeak93
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
