Bearings Look Bad? Advice :(
  • Thread starter Thread starter TRIBUNAL
  • Start date Start date Oct 23, 2016
First Prev 2 of 2
General karthief
Mod Dude
Aug 25, 2016
28,142
10,761
213
polk county florida
Oct 26, 2016
#21
  • Oct 26, 2016
  • #21
He was probably talking about the holes in the crank that feeds the bearings, they get the sharp edges filed down in the direction the crank spins, champhered or something like that, anyway it makes it oil the bearings better. Someone here can explain it better.
I would start out with a stock cam, you can always up grade later, alphabet cams are old tech, better stuff on the market now.
Boosted92LX
5,721
4,244
224
Oct 26, 2016
#22
  • Oct 26, 2016
  • #22
Oil *GALLEYS.. the passages thru the crank that are pressurized with oil and feed it from the mains to the rod journals.. also found in the block.
But one piece bearings? Laser welded?
Reactions: A5literMan
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 26, 2016
#23
  • Oct 26, 2016
  • #23
That's what I said to myself.....
Dafuq are laser welded single piece bearings.
Boosted92LX
5,721
4,244
224
Oct 26, 2016
#24
  • Oct 26, 2016
  • #24
Made from transparent aluminum....
T
TRIBUNAL
103
Oct 26, 2016
#25
  • Oct 26, 2016
  • #25
lol yea I'll have to get the details tomorrow when I bring it down maybe I misheard, I really wasn't fallowing him when he was describing how they install it.
T
TRIBUNAL
103
Oct 26, 2016
#26
  • Oct 26, 2016
  • #26
You know I am just thinking I don't want them to use "their" springs on the heads and wind up having to do machine work because they're not exact fits,
These springs are right with a stock mustang HO cam right?
http://www.alexsparts.com/valve-spr...lift-cams-high-output-drop-in-up-to-540-lift/
General karthief
Mod Dude
Aug 25, 2016
28,142
10,761
213
polk county florida
Oct 26, 2016
#27
  • Oct 26, 2016
  • #27
And what is wrong with transparent aluminum? As you can't see, they never go bad.
stykthyn
5,232
2,652
223
gainesville
Oct 27, 2016
#28
  • Oct 27, 2016
  • #28
That's what holds my whales
Reactions: Boosted92LX
T
TRIBUNAL
103
Oct 27, 2016
#29
  • Oct 27, 2016
  • #29
So apparently their like clevit, clevit used to use them a while back I think the name began with D. Anyway he said they make them in the factory by using high energy electric welds which they call laser welds which prevents them from coming apart.
Bad news is there is a significant ridge so I got burned with the junk yard motor... might be ok to rebuild, hes going to boil and measure it tomorrow. If not, it might be the end of the project. and rebuilding the heads will be a ridiculous 600+ so i don't know what I will do for heads even if i got the bottom end done because it seems restarted to spend $600 for stock gt40p iron heads..
Bummer...
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Oct 27, 2016
#30
  • Oct 27, 2016
  • #30
What? 600$ to rebuild the heads huh....
Gold wallpaper in his office?
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Oct 28, 2016
#31
  • Oct 28, 2016
  • #31
While on the high side, that's not too far off. I had a little over $400 in mine, and that wasn't counting the 18 hours I put into porting them.
-cleaning
-milling
-cut spring perches for dual Springs
-valve job
-Springs, seals, retainers
-I had my bowls machined open at shop prior porting
-another cleaning
-final assembly
It adds up. I didn't need any valves replaced, guides replaced or seats replaced, so factor those possibilities in too.
Joe
Reactions: A5literMan, RaggedGT and Davedacarpainter
Boosted92LX
5,721
4,244
224
Oct 28, 2016
#32
  • Oct 28, 2016
  • #32
The most I've ever spent on machine work for heads was 300. Provide your own springs and hardware and save some money. Most of those guys will give you a 10%-20% markup over retail.
OR, if your cam isn't too radical, have the pressures checked on your old springs and reuse them if that isn't out of spec.
Reactions: RaggedGT and a91what
T
TRIBUNAL
103
Nov 1, 2016
#33
  • Nov 1, 2016
  • #33
Update*
Good news for a change, "It cleaned up, it's not pretty but it cleaned up, wont need to bore it out, still have to hit it with some sand paper and work but it cleaned up"
Whew.
So now that that bullet is out of the way I can start trying to think about what I need to do for heads. I could bring them to another shop, that S&K while top notch is also top price.
I think I will make anew post for heads, I have some ideas I would like to see what people think.
First Prev 2 of 2
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
new edge coolant leak need advice asap
  • 2vBoogs
  • Nov 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Nov 19, 2026
Mustang5L5
