Before I finish this 347...
SR86
146
Alberta, canada
Ok, so the 302 sold today...Time to get these parts ordered and this motor thumping!
Here is the build:
347, H-beam Rods, Cast crank, Main girdle, CentreForce billet flywheel, pro-bond SFI dampner.(Already built)
The wish list:
Canton Windage tray, Canton pan, Trick Flow Track heat intake(1500-6500 RPM range), Comp XFI Stroker cam, 579 total lift, AFR185's non Emission, BBK 75mm TB and spacer, 30# injectors,
Any final thoughts before the cash is outlayed? did I miss anything?
In a 5-speed, 3500lb ranger.
