Bellhousing for 351
408stroker5.0
The world would be a better place if all males jus
Mar 10, 2004
639
Bonnyville, Alberta, CANADA
Good call 5.0HOTrain.... keep in mind also mcjc00 if your making any kind of power with that 351W your going to want to seriously consider swamping out that T5 for a Tremec or some kind of built trans (G-Force T5, Richmond, etc. etc.). The old T5 wont stand up to too much abuse from a high powered windsor. If it's in your budget I'd definetly invest in a good trans. to support all that power. If it's a mild 351W you can get away with the T5 for a while...
351LX
1,007
Regina, Saskatchewan
Your 5.0 T-5 flywheel will bolt to the 351w but it is the wrong balance.302's made after 1981 are 50 oz while 302's made before 1981 and 351w's are 28 oz.You will have to buy an aftermarket flywheel with the right balance for a 351w or have your 302 flywheel balanced for a 351w.
