If I am running an alternator, ps pump, ac, and electric water pump. I would run on the outside of the alt, ps, ac, and crank, with the tensioner doing what it is supposed to do. So I would have a big circle with the belt, correct??
Everything with the exception of the water pump run clock wise (assuming your referring to an 87-93 fox) so if that's how you have it then I would think it would work
