  • 1994 - 1995 Specific Tech
belt tensioner...
  • Thread starter Thread starter milewsky80
  • Start date Start date Sep 24, 2007
milewsky80
69
Weirton, WV
Sep 24, 2007
  • Sep 24, 2007
Has anyone taken theirs and grinded down the stop so that it has more adjustment? Ever since bypassing my smog pump I haven't been able to run a belt more than 5 months without it squealing. Good idea??
parchisi
519
New Mexico
Sep 24, 2007
  • Sep 24, 2007
I guess I don't really understand what grinding down that stop would do. there's already an area of adjustment, and I'd think you should be able to find a belt that fits in that area. Perhaps your tensioner is just worn out and is not providing enough tension?
1slow95
1,797
ohio
Sep 24, 2007
  • Sep 24, 2007
What I did was buy a replacement idler pulley and put it in place of the tensioner pulley. My idler was hitting the stop and knocking, but now I've got over a 1/4" clearance between the tensioner and the stop.
milewsky80
69
Weirton, WV
Sep 24, 2007
  • Sep 24, 2007
Were the pulleys a direct swap? That seems like it would be a lot easier than my idea and I know that it has worked for someone.
1slow95
1,797
ohio
Sep 24, 2007
  • Sep 24, 2007
I had to use a smaller washer, but otherwise it was a direct swap. Some parts store are selling ridiculously wide pulleys that won't fit, but the stock size will fit just fine.
Pokageek
2,767
MA, USA
Sep 24, 2007
  • Sep 24, 2007
I think it depends on if you have a 94 or 95 believe it or not. Mike, check out my thread and link to a pic of my stock idler..it looks nothing like yours and wont work.
1slow95
1,797
ohio
Sep 25, 2007
  • Sep 25, 2007
My stock one looked like that, both of mine now are parts store replacements. Why doesn't it work? Does it hit on the tensioner somewhere?
Pokageek
2,767
MA, USA
Sep 25, 2007
  • Sep 25, 2007
The back of the pulley hits on the metal nub that it bolts into.
1slow95
1,797
ohio
Sep 25, 2007
  • Sep 25, 2007
That's what I was afraid of...Mine is hollow on the back side of it, and it fits just fine...
I know I posted this in the other thread, but I'll post it again for milewsky80. This is the pulley you need...
G
GTSSTANG
14
#10
  • Sep 25, 2007
  • #10
I had to grind down the stops on my tensioner.. It gave me a bit more room to run a smaller belt..
I am Vortech Supercharged and the alt. is moved in and messes with the belts postion. Every belt I bought would stretch within 50 miles and rub against itself. I used gates, gator back and napa belts and they all would stretch atleast an inch... so grinding gave me the little bit of give I needed.
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
