  • 1994 - 1995 Specific Tech
Bend the frame?
  • Thread starter Thread starter fords2fast4u
  • Start date Start date Apr 26, 2005
First Prev 2 of 2
fords2fast4u
1,426
Mission Viejo, CA
Apr 28, 2005
#21
  • Apr 28, 2005
  • #21
i don't think anyone is going to be able to set it - that's why i'm wondering if anyone else has ever had this problem?
this really sucks because i can't drive my car until i get this fixed..
fords2fast4u
1,426
Mission Viejo, CA
Apr 28, 2005
#22
  • Apr 28, 2005
  • #22
can i just get shorter front struts???
94-302-vert
1,947
NE CT
Apr 28, 2005
#23
  • Apr 28, 2005
  • #23
on my D&D's from the centre of the strut to the edge of the lower plate is ~3". Now my car isn't aligned yet but I did a visual alignment (camber is slightly negative) and I have ~.5" between the large lower plate and the fender.
How wide are the steeda's?
Chris
fords2fast4u
1,426
Mission Viejo, CA
Apr 28, 2005
#24
  • Apr 28, 2005
  • #24
i haven't measured them, but you can see them in the pics. I checked out the D&D's a second ago, but i think i'd rather get new/shorter struts before i replace the 200 dollar items.... jmo
94-302-vert
1,947
NE CT
Apr 28, 2005
#25
  • Apr 28, 2005
  • #25
not to replace...
struts have nothing to do with this. it is the distance between the control arm and upper mounting point. this is controlled by the spring.
If you are close modify the steeda's... worst case you have them reinforced after... I wouldn't lose out in $200 when a cheap fix can be had...
Chris
fords2fast4u
1,426
Mission Viejo, CA
Apr 28, 2005
#26
  • Apr 28, 2005
  • #26
that's just it though, i don't think im anywhere close...
WhiteDevil
2,717
San Diego
Apr 28, 2005
#27
  • Apr 28, 2005
  • #27
THis is a very interestng thread for me. I have always had this problem with my drivers side wheel stickig out slightly from the fenderwell definitly more than the passenger side. I was with LoudToy lookin at my car and he noticed that my stock caster camber plates are both pushed all the way to the same side. If you are looking at the engine bay they are both all the way to the right. Which is why that one wheel sticks out. Im not sure why that is but im gonna take it in to get check out and ill probably pick up some MM Caster camber plates too.
fords2fast4u
1,426
Mission Viejo, CA
Apr 28, 2005
#28
  • Apr 28, 2005
  • #28
i went with the steedas because im on a budget, but now i wish i had gotten the D&D ones or other internally adjustable ones...
im going to get it to the alignment shop tomorrow and let you guys know whats going on...
CManT1914
3,172
Killeen, Texas
Apr 28, 2005
#29
  • Apr 28, 2005
  • #29
Wow, I've never heard of anyone ordering Steeda's due to being on a budget, lol. Steeda isn't exactly cheap. Good luck, and let us know what the alignment guy says.
fords2fast4u
1,426
Mission Viejo, CA
Apr 28, 2005
#30
  • Apr 28, 2005
  • #30
94-302-vert ... the diagram shows 4 different bushing placements for different length struts matched with different length springs... if the strut is shorter, doesn't that mean that the plate has to move less to achieve the same degree of change?
This is hard to visualise with out an aid....
94-302-vert
1,947
NE CT
Apr 28, 2005
#31
  • Apr 28, 2005
  • #31
Hmmmm....
Let me think about this as I type...
If you move theshims around from under to over the C&C plate, or vise versa are you really changing the geometry...
I am going to say no because if the C&C plate is cinched down and you move how much of the strut rod protrudes though it you do not change your alignment because the strut will still be along that same line only now it will be working in a different part of the stroke of the strut s you hit bumps.
I think you may need to trim the plate...
So is you camber too negative or positive? (top of the tire in the fender or out of the fender)?
Chris
fords2fast4u
1,426
Mission Viejo, CA
Apr 28, 2005
#32
  • Apr 28, 2005
  • #32
NEGATIVE...
Camber -2.1*/-1.8* (both red)
the rims cant inside the fenders... the lower part of the rim sticks out.
i think the pic on page shows it well enough, and i have pic on there about how/where i would need to cut them. They're just brand new and cost me 160 bones, so i don't want to go cutting them if i dont have too, you know...
First Prev 2 of 2
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
Strut Tower Help!
  • 93Nifty
  • Jan 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
General karthief
Foxbody adjust alignment
  • Creomod
  • Jun 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2025
2000xp8
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
