Bent Push Rods
  • Thread starter Thread starter rdnkjdi
  • Start date Start date Aug 25, 2007
R
rdnkjdi
17
  • Aug 25, 2007
I pulled my head to replace my head gasket, and one of my push rods is bent a lot. It's been gouged from rubbing. At least one other is noticeably bent. Somebody suggested I might be able to straighten them rather than get new ones. This strikes me as a bad idea, but I wouldn't mind getting my engine put back together today. Should I straighten or get new ones?
Is there anything else I should do\check for while I've got the head off?
BlwnGazkit
153
Richmond, VA
Aug 25, 2007
  • Aug 25, 2007
Push rods are cheap, just replace it and don't chance it.
Plus it's asking for trouble to straighten a pushrod and reuse it.
Make sure you replace it with the correct length.
dbfarr
191
Boise ID
Aug 25, 2007
  • Aug 25, 2007
Uh, push rods typically shouldn't just bend on their little own some. Check your valve train geometry, coil bind, etc. Or, install a rev limiter.
I may, and am, usually incomplete or wrong. So, as far as I know, over revving or incorrect valve train geometry are the only ways to fubar a push rod. Maybe oiling problems. So, in short, find the source,... then replace the push rods.
For sure, don't straighten them, they're junk. Except for maybe prying at things... I used one to lock the armature on a 3g alternator when I was zapping the pulley off/on.
BullittStangV8
1,104
NJ
Aug 25, 2007
  • Aug 25, 2007
My vote is to get new ones. I bent a pushrod on my motor, and it cost me a whole rotating assembly/block. I dont know if other things went wrong and then bent it, or it bent, and caused the problems.
R
rdnkjdi
17
  • Aug 25, 2007
I've been thinking about how they got bent...and a few times gotten my car WAY too hot. I never could figure out what was happening to the water...so far I've replaced my thermostat, radiator trying to fix it, but I'm thinking it was the head gasket. I got it so hot it cracked my exhaust manifold. Could that've warped my rods?
BullittStangV8
1,104
NJ
Aug 25, 2007
  • Aug 25, 2007
I bent my rods/valves when my rpms got wayyy to high.
rbohm
6,698
550
204
tucson,az
Aug 25, 2007
  • Aug 25, 2007
first get new push rods. as stated they are cheap.
as for why they bent, there are a number of reasons, including;
coil bind
valve float
excessive rpm
valve to piston interference
bent valves
check these areas over carefully to be sure you have no problems in these areas.
H
headgrinder
33
san rafael ca.
Aug 25, 2007
  • Aug 25, 2007
bent p/rods
A sticking valve can cause a bent push rod. It can stick due to carbon build up,lack of lubrication or excessive heat. If you know what cyl/and if it was an int or ex. you can do a simple but not definitive test by tapping on the suspect valve on the spring side and compare the sound (if it moves or not) to another valve if it does not move
you have a stuck or sticking guide if it seems fine remove spring and inspect valve stem anyway.Now is a good time as it is much harder to do after head is back on.
ps make sure that the head is on side so you dont tap valve into contact with table/ground and bend it.
Good luck
p0prcksandc0ke
111
sacramento,ca
Aug 25, 2007
  • Aug 25, 2007
same thing happend to me cost me 46 bucks to replace all of the pushrods
D
D.Hearne
11,730
south louisiana
Aug 25, 2007
#10
  • Aug 25, 2007
  • #10
coil bind
valve float
excessive rpm
bent valves
Add wiped cam lobes and pulled out rocker sutds to this list.
MustangMatt1966
1,004
Orlando Fl.
Aug 26, 2007
#11
  • Aug 26, 2007
  • #11
just a stupid question but what is "coil bind"?? just wondering
rbohm
6,698
550
204
tucson,az
Aug 26, 2007
#12
  • Aug 26, 2007
  • #12
coil bind is where the valve springs, or any other coil spring, reaches its maximum compression capability, and becomes for all intents a solid cylinder. it wont compress any further, thus the coils "bind". this can happen in two ways;
you use a cam that has more lift than the springs were designed to handle
you float the valves
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
  • Mindseye007
  • Aug 16, 2026
Mindseye007
