bent valve
  • Thread starter Thread starter shttygtstang
  • Start date Start date Nov 7, 2004
shttygtstang
978
  • Nov 7, 2004
can i take the driver side head off with out taking the lower intake off just undoing the bolts for that sidemaybe sliding it off
well got my combo all together and theres been this sticky valve i had i just thought it was sticking because there was no oil it would stick for only a second .its bent and my roller rocker wont stay alinied on it straight because every time the valve compresses it takes a sec to come back up and the roller rocker is loose the push rod gets slamed into it and it gets bent
also were do i find an exhaust valve for edelbrock heads
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 7, 2004
  • Nov 7, 2004
You're gonna have to take the lower intake off in order to get things to seal properly when you put it back together. The intake is designed to be pulled/torqued down evenly on both sides. So you won't be able to do what you suggest - I think there's even a chance you could break the intake doing it that way. Chances are slim in my opinion that you'd get it to seal. In any event, you'd never get a gasket in there - think about assembly.
The real question is how did the valve get bent? I can't remember the details of when you were putting it together, or if you've had it apart. Valves usually get bent because they've hit a piston. Do you have potential p to v clearance issues?
No sense in just replacing the valve until you find out why it got bent - and solve that problem too. Otherwise, you'll likely bend the new one.
shttygtstang
978
  • Nov 8, 2004
micheal the guy who sold me the heads sold it to me with a bent valve i allways thought it was sticky till i had a good freind look at it
i know i have at least 70,000 of an inch because that thicker head gasket i have and evey thing else is fine well i called jegs and they want 24.99 for an exhaust valve
shttygtstang
978
  • Nov 8, 2004
would my bent valve cause my rocker arm not to sit on the right cause im having that prob to
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 8, 2004
  • Nov 8, 2004
Bent valves can cause all sorts of geometry issues. Can also damage the valve guide - are you gonna have the head - rest of the valves looked at? Like I said, whether you did it, or the previous guy did it, if there's one, there could be more.
Decided to go with the thicker gasket even though we told you not to, huh? Good luck with it - by the way, the accepted minimums are .080" intake; .100" exhaust - so at .070" you're still pushing your luck.
shttygtstang
978
  • Nov 8, 2004
yes of course ill look at the rest
i had the car running fine of 7 cyl yesterday i think the rest are ok but i look to make shure
bent valve would be the reason i gotem so cheap though people are messed up i would still bought em if i known now i went through all this have to do it all over
the reason i still went with that head gasket is because thats what i was told to use from bennet racing and they really know there stuff so i trusted them
thanks micheal for the insite though you havent steered me wrong yet
shttygtstang
978
  • Nov 8, 2004
well took me an hour and half and i didnt need to take the lower off only take all the bolts out didnt have to undo the fuel lines ect
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
G
4.6L rods and piston into a 5.4L
  • Green mustang
  • Jun 11, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 11, 2025
Green mustang
G
