Best Overall Spark Plug ?
The most basic copper plug you can find. Avoid hype, avoid anything that has "split" or "fire" or "platinum" or anything referring to enhanced performance. That is assuming the engine is stock, but then if it's stock why are you running 93?
Reactions: aar0s
I agree.. Copper plugs all the way. My motor is stock with the timing bumped, that's the only reason I run 93
no problem...
like i said im pretty sure thats the correct heat range but not 100%. im sure some one will correct me if im wrong
Hard to beat the tried and true Autolite copper plugs. Agree avoid the "hi performance" Splitfire, E3, or platinum plugs. Pure waste of money and I've seen them foul more times than I can count. Even on my blown or nitrous cars I went with colder autolites and never had a problem.
Buy the cheap ones, replace them often. If you get bored, look into indexing and strap modifying...If nothing else I've found some pretty significant improvements in throttle response on my car by using both.
NGK is the OEM plug for Nissan/Infiniti. They are good quality plugs. They also make copper versions, in addition to platnium and iridium.
With a stock fox Mustang, i'd recommend copper. Most of the time, i'll say get copper OEM motorcraft plugs.
BTW Motorcraft and Autolite split ways in the 60's. Their plug machines are the same, but they are not the same plug despite looking identical. I've "heard" that the motorcrafts plugs specs are tighter than Autolite
