getting tuneup this week and changing plugs, I love to get on it and im a daily driver, what plugs to go with?
stangGT97 said:Autolite 764 or Motorcraft AGSF-32Cs gapped @ 0.054. If you're running into detonation issues, drop a heat range to AGSF-22Cs or Autolite 103s.
Matt's 03 GT said:Is there any issue with running the lower heat range on a mostly stock engine?
Ok, heat range has to do with the heat transfer properties of a spark plug... and it has nothing to do with the spark itself. A spark plug that is 1 heat range colder will remove more heat from the tip of the plug, lowering combustion temperatures - this will aide greatly in helping to prevent preignition/detonation. If your combustion temperatures are too high, your fuel can pre-ignite, before being fully compressed and ignited with the spark. This will lead to audible pinging and eventually the destruction of your engine (if not corrected quickly). So if you are having detonation problems, sometimes a higher octane fuel can correct it, but if not, running 1 step colder might do the trick.Team Ford said:can you elaborate on heat range a little more.
Matt's 03 GT said:Thanks very much. I have been having a Pinging problem when the temp is over about 80 degrees. I may try the colder plugs to see how it changes... I'll let you know.
:SNSign:
The good thing about installing Motorcraft spark plugsexindust said:Motocraft
Because Kilgore Said So
Pennywise2 said:The good thing about installing Motorcraft spark plugs
is that they come pre-gapped.![]()
