Best way to test gauges?
okay, might be a tough one. Or a simple one.
I know with 12v gauges, you can just ground out the sending wire-assuming your power and ground is hooked up-and the needle should peg to the max.
However, I believe the stock gauges are regulated by their own inst. cluster regulator. that might complicate things.
anybody care to add?
the best way would actually be with a variable resistor, (guage tester) so you can simulate the low and high readings of each guage, specs you would have to check with the shop manual but as an example a fuel sender may be 15 ohms for empty and 70 ohms for full. and obviously readings in between would vary the sweep of the needle
Gord
