Bewildered
  • Thread starter Thread starter wv109323
  • Start date Start date Sep 1, 2011
W
wv109323
100
Lenore ,WV
Sep 1, 2011
  • Sep 1, 2011
I have a 1992 Gt project. The engine is stock except it has and E-cam. I am at the point that I would like to get the car on the road and drive it some.
I have done the following:
I have no codes. I have no Check Engine Light.
I have replaced the Ignition Control Module.
I have cleaned the 10 pin connectors.
I have cleaned the computer terminals.
I have cleaned the engine and computer ground wires.
I have replaced the PIP sensor.
I installed a second whole distributor.(another pip and ICM)
I installed and set a new TPS.
My problems is the car jerks and bucks when releasing the clutch. (1st gear and reverse). The engines stalls/dies unless the RPMs are up around 1500-2000. The car can starting jerking and bucking when the throttle is applied after the clutch is released.
The engines has a slight studder/shutter when coming off idle around 1100-1200 RPM. This is under no load just reving the engine up(depressing the accelerator peddle). Then the engine revs fine under no load all the way to 5500RPM +.
When under load the engine will not rev above 4400-4500 RPMs. The engine is smooth but will not exceed 4500 RPMs under load. ( No spitting or Backfiring)
Today I put the car in 1st Gear, I drove down the road for 1/4-1/2 mile with the accelerator depressed and the engine would not exceed 4500RPMs. The car pulls strong up to 4500RPMs and then literally quites making power. Same thing in second gear; engine pulls strong up to 4500RPM and then the car will not go faster unless shifter into 3rd gear. When the car is below 4500 RPM I can not detect a miss or anything.
Spark plugs look good. They are Autolite. Estimated 2000 miles on them
Plugs wires look good.Rotor Cap nearly new
What would you look for/Change/Test
Awaitng your thoughts.
LarsD
2,680
119
123
Texas
Sep 1, 2011
  • Sep 1, 2011
I had a car years ago that wouldn't pass a certain RPM. Changed a ton of parts and didn't fix it. Turned out it was the fuel filter.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
