Big Block 5-Speed?
  • Thread starter Thread starter 98coyote
  • Start date Start date Feb 23, 2006
9
98coyote
24
Leighton, Alabama
Feb 23, 2006
  • Feb 23, 2006
I have a 71 Mach1 that I will be swapping a 460 into, it is currently an automatic, but I want a Tremec 600. Has anyone done this swap, if so where is the best place to buy the parts.
steel1212
1,180
Frankfort, Ky
Feb 23, 2006
  • Feb 23, 2006
I'm sure anything is possible. I would bet they have a scattersheild type bell houseing that might work or one of those companys could probably make you one. As for the conversion kit, I don't see much for the 71 but then again.... I haven't looked lol.
G
Gud T.B. Blown
583
Feb 24, 2006
  • Feb 24, 2006
from what i've read the tremec is going to require you to modify your trans tunnel to fit, however a richmond will bolt right in. the downside, of course, is the cost of the richmond.
rbohm
6,698
550
204
tucson,az
Feb 24, 2006
  • Feb 24, 2006
as i recall, lakewood has a bellhousing that works on the 429/460 block, and the 71-73 mustangs should have the tunnel room for the tremec, but the richmond 4+1 would be a better choice.
H
HHStang
566
Coastal SC
Feb 25, 2006
  • Feb 25, 2006
No way I'd get a Richmond. Three friends with very bad experiences. Get a TKO, TKO500 or TKO600, Lakewood bell and look real hard for the pedal assembly and linkages. If you do find pedals but no linkages, you can also go with a hydraulic thow out bearing. Plenty of room for TKO's in 71-73's. Best place to find pedals is probably vintage-mustang.com in classifieds, Might get lucky here though. Dark horse performance or Modern drive line has all you need (other than pedals).
G
Gud T.B. Blown
583
Feb 25, 2006
  • Feb 25, 2006
have you installed a tko into a '71-'73?
H
HHStang
566
Coastal SC
Feb 25, 2006
  • Feb 25, 2006
I installed a TKO on my 466 in my 67. I took out manual and put C-6 in "wife's" 72 Mach One 429 clone. Both cars are up on jacks in my garage right now. Why?
4MuscleMachines
417
South Texas
Feb 25, 2006
  • Feb 25, 2006
I have a TKO-600 in my 71 and the car is on the road. No fitment issues whatsoever, slipped in like fine shoe.
G
Gud T.B. Blown
583
Feb 26, 2006
  • Feb 26, 2006
i asked because i had read more than once that there were fitment issues but the authors look to have been wrong.
4MuscleMachines Quote:
was this a straight bolt in?
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
