Why has no one made a big bore short stroke engine like this,
5 inch bore and 2.5 inch stroke V8 or prefer a V12. Although a V8 is cheaper on mass production and (V12 due to more cylinders making for a smoother engine) also use long rods and thin piston rings.
This would rev high, and due to the large piston surface area make up for the torque of a short stroke as well as less ring friction, plus unshroud the valves.
Also equip this with Coates rotary valve heads for 10-15K rpm, he was trying to sell this design to the big 3 but they already had to much invested in the old ancient poppet valves.
If only I had a few million dollars lying around for R&D I could set capitalism aside and make something special for the masses
Here is a article about the different 383's explaining my whole point THANK YOU
