Big Problem with engine
  • Thread starter Thread starter tango7
  • Start date Start date Aug 30, 2004
T
tango7
155
Hickory n.c
Aug 30, 2004
  • Aug 30, 2004
Here is what had been done. stock pistons notched for trick flow stage 2 cam and canfield heads longer push rods 1.6 roller rockers and a pete jackson gear drive, Holley intake and 70 mm throttle body,24 pound injectors, and c& L meter calibrated to the injectors. fired the engine up it cranks right up but will not idle and when you try to rev it up it all of a sudden jumps up. will not take the fuel slowly. It also pops back through the intake. I have adjusted the rockers. I even had someone else come and adjust them still the same.
Could the pete jackson gear drive be a tooth off and cause this problem I have had someone run the car and I used a timing light to check timing it is ok by the mark and it is set on 14btc. anyone have any ideals.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 30, 2004
  • Aug 30, 2004
Did you degree the cam on install to be certain of the cam timing? Have you pulled the diagnostic codes out of the computer?
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
