bigger fuel system??
  • Thread starter Thread starter 90pony302
  • Start date Start date Aug 8, 2004
9
90pony302
65
southern illinois
Aug 8, 2004
  • Aug 8, 2004
any help you guys got would be greatly appreciated. i just got done putting some more mods on my gt. stock heads got a five angle valve job and milled .030. i removed smog pump, installed an electric fan, comp cams shaft (new lifters, springs, and still got stock pushrods) cant think of what duration is but the lift for the cam is .512 int and exh. and i installed trick flow 1.7 rockers and put on a TF track heat upper and lower intake with a 3/8 in. spacer. along with my other mods is it time to upgrade to bigger injectors, fuel pump, and grab an adjustable FPR? The reason i ask is cuz the engine revs fine from idle up until about 4500 then it starts fluttering like its not gettin enough of something??? i changed plugs and checked wires that helped but didnt get rid of the problem
HISSIN50
34
129
Aug 9, 2004
  • Aug 9, 2004
if you dont have one, a FP gauge is gonna be a friend now. see what pressure you got at higher revs. good luck.
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
