Bigggist Small Block Ford??
  • Thread starter Thread starter M9AbC
  • Start date Start date Mar 24, 2004
M9AbC
460
Florida
Mar 24, 2004
  • Mar 24, 2004
Ive heard that ford made a 400 small block for like 2 or 3 years...? Does anyone know if this is true? What is the largest small block ford ever made?
Anyone with sites or ideas were to find info like this for all of the big three would be great.
Thanks,
Ryan
5.0 HOtrain
2,247
New Hampshire
Mar 24, 2004
  • Mar 24, 2004
Ford's 400 was more big block than small block. Garbage anyway. 351 is the biggest small block they made.
M9AbC
460
Florida
Mar 24, 2004
  • Mar 24, 2004
Ok. But did for consider it a Small block? or a big block? Also what is the dif between a small/big block.
Thanks again,
Ryan
408stroker5.0
The world would be a better place if all males jus
Mar 10, 2004
639
Bonnyville, Alberta, CANADA
Mar 24, 2004
  • Mar 24, 2004
Ford did consider the 400 a small block, even though they are kind of a bulky engine. It is basically the same as a 351M exept the 400 has a longer stroke. These engines found themselves in late 70's early 80's Ford Trucks and some big cars.They are definetly not a motor that belong in a 5.0 Stang if you were thinking about it.
351LX
1,007
Regina, Saskatchewan
Mar 24, 2004
  • Mar 24, 2004
In my Ford Motorsport catalog Ford lists the 400 as being part of the small block family.Hot Rod magazine did a low buck build-up on one a few years back that had very impressive power for around $2000 http://www.geocities.com/styleline58/400.html The whole small b-big block thing is more of a GM thing but if you define a small block as any motor that shares the same cylinder head bolt pattern as a 302 then it is part of the small block family.
slackr
110
Denver
Mar 24, 2004
  • Mar 24, 2004
and if you define a big block as having the same bell housing bolt pattern as the 385 series 429/460, then it is part of the big block family.
how are you defining small/big block?
5.0 HOtrain
2,247
New Hampshire
Mar 24, 2004
  • Mar 24, 2004
Thats what I base my thought on, same as slackr.
hllon4whls
BANNED
2,567
Covington
Mar 24, 2004
  • Mar 24, 2004
Not really junk. Just different. Not as common. Lower number motor.
Same cylinder spacing as a 302/351/351c/351m but bell bolt pattern like a 460.
Very long stroke in that engine. Good for making lots of torque. With some good pistons, intake and some cleaned up heads, it makes a nice motor. Maybe not for a stang, but great for a 4x4
siege
651
Peoria, AZ
Mar 24, 2004
  • Mar 24, 2004
while we're on this subject, what is the biggest 351 based smallblock you could make? On horsepower TV they took a chevy 350 block and made a 472...just wondering how a ford would compare....
slackr
110
Denver
Mar 24, 2004
#10
  • Mar 24, 2004
  • #10
i've seen kits up to 454cid for a stock block 9.5" deck height 351w..... using a crank from a 400 i believe...
351LX
1,007
Mar 25, 2004
#11
  • Mar 25, 2004
  • #11
In 1973 Ford cast some of the 400's with a dual bellhousing bolt pattern so you could use the 302 bellhousing or the 429-460 one.The are sort of rare but I see them on ebay from time to time.
5.0 HOtrain
2,247
New Hampshire
Mar 25, 2004
#12
  • Mar 25, 2004
  • #12
I believe with a block you can bore big like a dart, you can go 454ci with a windsor, not sure of any other possiblilities. hllon4whls, you're right about the 4x4 with the 400, my first rig was a 79 broco with one.
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Mar 25, 2004
#13
  • Mar 25, 2004
  • #13
Biggest factory Ford small block = 427 which is based on the 351. I think the 428 and 429 were big blocks.
5.0 HOtrain
2,247
New Hampshire
Mar 25, 2004
#14
  • Mar 25, 2004
  • #14
With a .03 or .04 overbore maybe, with a dart block with big stroke and a .125-.2 overbore you can get 440+ cubic inches.
M
Moxie
523
Plymouth, MI
Mar 26, 2004
#15
  • Mar 26, 2004
  • #15
Dart Block
With a 9.5" deck Dart Iron Eagle block, you can use a maximum 4.185" bore, and 4.250" stroke, for a total of 468 cubic inches.
IMissMy93Fox
143
#16
  • Mar 26, 2004
  • #16
I the biggest you can go off a normal ford block is 427 off a 351C if i'm not mistaken.
5.0 HOtrain
2,247
New Hampshire
Mar 26, 2004
#17
  • Mar 26, 2004
  • #17
You can get that with a 351 windsor too
speedmaster new 302 block?
  • rednotch
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2026
rednotch
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Yesterday at 10:14 PM
DangStitches
D
Harrop - Eaton TVS style supercharger for small block Ford
  • nicholase
  • Jan 2, 2025
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
