BILL 302 COME TO THIS THREAD
bill from gadsden hopefully you can help me somemore with this.my car is a 94 teal gt thats been completely converted to 96 cobra body panels with steeda wing.it was stolen with engine parts stripped.so this is where it started.the shortblock was the only thing left in the engine bay,computer was gone air bags were gone.so i bought a running 94 black on black gt 5 spd drove it home and stripped it of everything.put rebuilt e-7s on because i didnt want to take a chance of ruining a new set of edelbrock heads i just bought.i rebuilt the short block my self and a man from my local machine shop told me to coat the cylinder walls with p b blaster to keep moisture off of them.anything else you need to no about this ask and ill tell you.i have to much invested in this car know to go any further without fixing the problem.
i might be over reacting about the heads and such all the temps,pressures are in spec and motor has no signs of knocking,overheating ect... have you tried to drive a short distance to see if smoke clears and if you do keep a good eye on the water temp.... or you can stop here and run a pressure test on the coolant system..
ok it can be difficult to bleed the system but the best way is to buy a thermostat with a bleeder hole at the top of the thermostat but if you have one without this hole you can drill a small hole at the top of the thermostat and it will help with bleeding do you know what i'm talking about????
the heads had a valve job,new springs,valves themselves were ground.thats about it.i didnt want to spend a lot on the heads as i had bought the edelbrocks.probably should have put them on i nthe first place by the way.im going to check your car out on car domain.i have my old 90 model triple white vert on there.in one of the pictures you can see my 94 in the back ground.
it is alot easier to bleed system with the bleeder valve mine didnt have one and i drilled a small hole in the top of the thermostat and i have never had to bleed or had and bleeding problems....hope everything goes well i will be on stangnet tommorrow after 2:30 pm...and thanks for checking out my ride i have recently added a compucar wet kit 90 shot of nitrous to my stang.....i have not added this to stangnet yet...
