Blinker Problems
-=Red5.0GT=-
108
I’m having a problem with my blinkers… they don’t work. I’m not sure what the problem is but the flashers do work. I do know that when I turn the flashers on they work and you can hear the relay working also. Do the flashers and blinkers use the same relay? I need help.
I’m not sure if this relates with the problem but I did install aftermarket euro gauges a few months ago. To power them I put the power wire (of the gauges) into the dimmer switch plug and then put the plug back together. Could that be the problem….
NEEEEED HELP
:shrug: :shrug: :shrug:
