Blinkers
  • Thread starter Thread starter Keith4452
  • Start date Start date Apr 12, 2006
K
Keith4452
14
  • Apr 12, 2006
Still having problems figuring out why my blinkers don't work . I have replaced the multifunction switch, ignition switch, flasher, checked fuses, and made sure all my lights work(not blown). I don't know if this is a ground problem, but as a possible hint the illumination doesn't work for my gauges and the fog lights don't work. I'm out of ideas and looking for new ones. Any suggestions will be appreciated, thank you!
-Keith
K
Keith4452
14
  • Apr 12, 2006
Ok, I have been searching past posts on this issue and found this: "you replaced the turn signal flasher relay? it is different than the hazzard relay. all the bulbs work? the bi-metallic spring in the flasher wont work as designed if there is too much or too little load on the circuit." Is this true? I replaced the turn signal flasher with the same one as the hazard flasher. Not sure if this is the problem...prob another long shot.
Saleen0679
876
24
49
Yakima, WA
Apr 12, 2006
  • Apr 12, 2006
Flashers have a lamp load spec and other guys have used the 552 to replace the turn signal flasher and haven't had a problem. The 552 has a spec of 1-6 lamps.
Can you hear the flasher trying to work?
Electrical Foxbody Dash & Hazard lights not working
  • sjmcr
  • Jun 30, 2025
Fox 5.0 Mustang Tech Jul 27, 2025
Mindseye007
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
Electrical 1986 Mustang GT Multifunction Switch Question
  • Willybill32
  • Oct 26, 2025
Fox 5.0 Mustang Tech Nov 22, 2025
Willybill32
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
