Block stampings?
  • Thread starter Thread starter Brando 91LX
  • Start date Start date Oct 17, 2006
Brando 91LX
36
  • Oct 17, 2006
I have 2 blocks. In the lifter valley one has XXX and the other has YYY. Does this have any significance?
Brando 91LX
36
  • Oct 17, 2006
Anybody?
W
woodsy
Banned
Oct 17, 2006
35
  • Oct 17, 2006
no signifigance, more myths about higher nickel content
Brando 91LX
36
  • Oct 18, 2006
thanx
Mustang78
486
Aberdeen, WA
Oct 18, 2006
  • Oct 18, 2006
i think the XXX is flat tappet cam/lifters, and the YYY block is roller cam..this is just what i've heard, you might wanna verify that before buying parts
~Mark~
M
Marlboro_Man
437
Houston, TX
Oct 18, 2006
  • Oct 18, 2006
~Mark~
My 87 block has "XXX" and it is a roller block.
My 89 block has "YYY" and it is a roller block.
So there goes that theory. I was wondering the same thing though, What does it mean?? Maybe different places they where assembled?
txstang84
1,639
42
69
Tuscola, tx
Oct 18, 2006
  • Oct 18, 2006
I think the foundry guys got bored one day and figured they'd have some fun with us...keep us guessing.
There used to be a rumor that only the HO blocks had it, but that's all balderdash too...hell most 5.0's bear the casting numbers E7SE, E7TE, F1SE or something like that...none of which are specifically designated for Mustang use only. there are very few blocks that were specifically for Mustangs, and most of them were back in the 60's and 70's (Boss, CJ, SCJ,)
Sims6986
50
Indy
Jan 1, 2007
  • Jan 1, 2007
sorry for bringing this thread back up, but the late model i pulled from my 70 mustang has e85e stamped on the block and the heads, as well as the XXX in the valley. What does this mean? I don't know what year it is, and it is fuel injected, which i'm getting rid of, so what manifolds can i use also? thanks in advance.
txstang84
1,639
42
69
Tuscola, tx
Jan 1, 2007
  • Jan 1, 2007
More than likely, the part number you saw in the block was actually E6SE...if the heads say E6SE...dump them in the junkyard...they're useless unless you're building a grocery getter. The block is fine to use unless you're building something to do 9's. No worries, all the roller blocks interchange...again, the XXX in the valley might just be some kind of identifier for the foundry.
aleborjas
610
#10
  • Jan 2, 2007
  • #10
wich one is the best one? stock ones....
seijirou
2,417
DFW
Jan 2, 2007
#11
  • Jan 2, 2007
  • #11
I hear the 'XXX' blocks tend to require more lube and are prone to be dirtier.
Sims6986
50
Indy
Jan 2, 2007
#12
  • Jan 2, 2007
  • #12
I'm planning a 347 stroker with aftermarket heads, but what intakes for a carb can i use?
GSP393
217
Orange County, Texas
Jan 2, 2007
#13
  • Jan 2, 2007
  • #13
The letter designation is the decade starting in the '60's with the letter C with the year following such as C9, being '69 followed by other letters/numbers. I'm not sure about the '90's. My 351w block for my stroker has D4 cast in it, so it's a '74 model block.
seijirou
2,417
DFW
Jan 2, 2007
#14
  • Jan 2, 2007
  • #14
It just follows the alphabet.
C = 60's
D = 70's
E = 80's
F = 90's
GSP393
217
Jan 2, 2007
#15
  • Jan 2, 2007
  • #15
C = 60's
D = 70's
E = 80's
F = 90's
That's what I meant, but you described it much better. Thanks
seijirou
2,417
DFW
Jan 4, 2007
#16
  • Jan 4, 2007
  • #16
R
Engine Block Identification
  • Ranger302
  • Feb 22, 2025
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
C
347 advice
  • CRonaldo773
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
2000xp8
Motor ID
  • 65er
  • Mar 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 14, 2026
C
Flat tappet to roller lifters--older block
  • chazmanaz
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
D
4.6L 4 valve Sleeve
  • DangStitches
  • Oct 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
