The driveshaft is mnost likely too far in the tail of the trans... I haven't ever had to use a spacer on a fox, and I've done a lot of them... The spacer issue is more of an issue on 94+ cars, along with spacers for the mounts on 1996+ although I shimmed a fox to get the trans level.
Measure from the center of the front u-joint to the tail of the trans, you should have 3"-3.5" max...if it is shorter the DS may be going in too far when the car trys to squat and the rear rotates.
What is the pinion angle set to? Is the trans level in the car, meaning the tail of the trans is level to the ground so the DS comes out straight or slightly angled down?
Put a closed breather on the V/C and hook back up the vac line going from the fill tube to the intake, right now you have un metered air which could be giving you some MAF issues...I've had cars that I was able to run open breathers on with no issues, and then found significant issues with them on others.
