Body dimension help
  • Thread starter Thread starter meanroy
  • Start date Start date Apr 22, 2005
meanroy
103
  • Apr 22, 2005
I am preparing to join the two halves of my project.
I find a puzzling difference in a dimension between the front clip and the rear section. Not big a one but around 1/2". The dimension is the floor flange to floor flange distance.
I have the factory underbody dimensions for the 65 but it doesn't specify the dimension from the floor flange to floor flange.
This is pecular because the Frame align dwg for the 69-70 does call out that dimension.
'65 frame align dwg:
'69-70 frame align dwg.
A fellow in germany claims the floor flange to floor flange dimension is the same between the two years. This is somewhat consistant with what I measure.
Have any of you measured this dim. on your car(s)?
Roy.
69 Rustang
307
Orange County California
Apr 22, 2005
  • Apr 22, 2005
Anyone measuring their car for this--be aware I think this is to be an inside edge to inside edge measure. Just want to make sure we get consistent responses.
meanroy
103
  • Apr 23, 2005
That is correct.
To clarify, I need a couple of people to measure one or both of the two dimensions shown in the diagram below.
I expect that the measurement of the inner rail will be slightly different at the top and bottom. (because of chassis flexability).
Your help will be much appreciated.
Roy.
PS.
Please specify whether fastback or coupe, and year.
They should be the same, I'd like to see the variation.
R.
geostang351
946
Danb., CT
Apr 23, 2005
  • Apr 23, 2005
I have a '68 coup. The measurement I got was 54 13/16" from inner flange to inner flange
M
mr-fixit
466
Malvern,Pa.
Apr 23, 2005
  • Apr 23, 2005
I looked in the '66 body dimension book I have, and it shows the measurement as 54 3/4 at what looks to be the jack point in the front. And 55 1/2 just ahead of the front mount of the leaf springs. (the measurements are from the same spots as your 69 diagram) I could fax you a copy on Monday if you wish.
Rick
meanroy
103
  • Apr 23, 2005
Thats great guys, it confirms the measurement as the same between the 65-66 and 69-70!
A little surprising but within what I can adjust mine to.
I get various dimensions ranging from 54-3/4 to 55-1/4 on the front clip and back half.
I'll set the dimension at or very near to the factory 54-3/4 dimension.
I started making the final cuts for fitting the two halves together yesterday.
I hope to start joining the halves this week!
Got my fingers crossed I can match everything up!
Rick
Whoops! you don't mean the rocker panels aren't parallel do you? That would be pretty strange, is there a chance you are looking at two simular but different measurements? I may have caused some confusion, what I refer to as the "inner rail" is called "112-212 ROCKER PANEL, Complete Inner" in the NPD catalog.
I don't have a fax, but I'll see if I can get access to one.​
Roy.
69 Rustang
307
Apr 25, 2005
  • Apr 25, 2005
Roy,
Not that I hold any stock in aftermarket parts or reproduction parts, but I did notice over the weekend that the same "full floorpan" that the parts vendors are selling works for all early model Mustangs from 65 - 73. The only difference noted was variations in ribbing. From this I think we can safely say that the rocker to rocker measurement should be the same from a 1970 to a 1965/66 model.
Dave
meanroy
103
  • Apr 25, 2005
69 Rustang said:
Roy,
Dave
Thanks Dave, now I feel stupid, I pore over catalogs all the time and never noticed that.
I'm going to go with the 54-3/4" measurement.
I may be able to get the final cuts finished today. I've been taking it pretty slow hoping I don't screw up, but it's time!
Roy.
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Needing help on the best way to tackle alot of sheet metal replacement
  • BoulevardofRustedDreams
  • Sep 13, 2019
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 14, 2019
2Blue2
'71 Trunk Floor In '65 Notchback
  • mckallister
  • May 12, 2016
3K
1965 - 1973 Classic Mustangs -General/Talk- May 12, 2016
mckallister
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
