Body Sanding
  • Thread starter Thread starter Myfirst67
  • Start date Start date Apr 26, 2004
Myfirst67
88
richmond, California
Apr 26, 2004
  • Apr 26, 2004
I want to try to do some bodywork on my car like sanding and wanted to know some stuff.Like should i use a sander or do it by hand? If i do use a sander weres the the best place to get them from for the best price and how many volts to look for?Also whats the best way to get Bond-Doh off
O
Ozsum67
Too much thin air
5,152
Eastern Colorado
Apr 26, 2004
  • Apr 26, 2004
I used an orbital sander that I got at Home Depot. Also, a small sanding block. Don't use your hands except for fine, finish sanding. You'll never get it even. Try an abrasive disk that goes on a drill to get rid of the bondo. It is really crude looking, but makes short work of it. I used one to rough out the bondo, or to get it close to form, before sanding. I'n not talking about one of the grinding disks. This thing is about an inch thick, and a few inches in diameter. Also, wear eye and lung protection.
Myfirst67
88
Apr 26, 2004
  • Apr 26, 2004
what grade of sand paper did u use on your sander?
Myfirst67
88
Apr 26, 2004
  • Apr 26, 2004
and a nother thing is your orbital sander a palm sander?
G
GaPonyFarm
663
Columbus, GA
Apr 27, 2004
  • Apr 27, 2004
You really need something more than a palm sander, or even an orbital sander. A good 4.5" grinder with sanding disks is a better tool for stripping. For prepping the body for paint you really need to use varying lengths of sanding blocks to prevent getting ripples.
For stripping I like to use 80 grit, sometimes with alot of paint/bondo I'll go to 40 grit.
O
Ozsum67
Too much thin air
5,152
Eastern Colorado
Apr 27, 2004
  • Apr 27, 2004
Yes, a palm sander is fine. The key is to start with a coarser grade and go up in fineness. I would start with a 100 as 80 is too coarse and you will spend wasted time getting scratches out.
Cobain03
996
Lexington, Ky
Apr 27, 2004
  • Apr 27, 2004
im using a palm sander now with 100 grit paper on it. also, as ozsum said, i used a thing you put into your drill and you can buy them for heavy/light paint striping or more as you need.
O
Ozsum67
Too much thin air
5,152
Eastern Colorado
Apr 27, 2004
  • Apr 27, 2004
Yea, kind of a poor man's way, but effective. You don't have to rush out and buy a compressor and a DA and body file and the like. You do need some sort of good eye though. Being **** eyed won't work.
allcarfan
The Answer Man
2,458
North Atlanta
Apr 27, 2004
  • Apr 27, 2004
I suggest a DA sander and a Pneumatic body File
O
Ozsum67
Too much thin air
5,152
Eastern Colorado
Apr 27, 2004
#10
  • Apr 27, 2004
  • #10
Like I said, no need to spend a ton a jack.
J
jae902
175
#11
  • Apr 27, 2004
  • #11
The proper way to do it is to use a DA sander. But not necessary, you can use a palm sander from sears. You have to use something that is vibrating to take the paint off. If you use a drill with an attachment, it will just rip into the paint and leave grooves. Why are you trying to take the old bondo off? Only take it off if you need to put new bondo on. Bondo work is hard stuff, not really hard but tiring. Otherwise, rip the paint off with a palm sander using 80 grit, then primer and wetsand it with like 300 grit. Primer again and then wetsand again.
O
Ozsum67
Too much thin air
5,152
Eastern Colorado
Apr 27, 2004
#12
  • Apr 27, 2004
  • #12
I can only asume that there is old bondo that, like all bondo, rust gets behind. The wheel is a great way to rip out the old in a quick fashion.
Myfirst67
88
Apr 27, 2004
#13
  • Apr 27, 2004
  • #13
Im taking the old bondo off because its broken up in some places.
67GTA-FB429
777
Tri-Cities, Wa
Apr 28, 2004
#14
  • Apr 28, 2004
  • #14
Get a low speed adjustable electric grinder with aa 8-10" pad. Use about a 36 grit to remove paint and bondo. Get a finer drit for just paint. The grinder is low speed high torque it will take everything off easily without throwing a lot of cr*p up in the air. This is what body shops use.
Something like this. make sure it has adjustable speed.
http://www.nikotausa.com/catalog/detail.asp?productid=222&subcatid=196
Myfirst67
88
Apr 28, 2004
#15
  • Apr 28, 2004
  • #15
I know were i can get a 4" Angle Grinder for $10 its not a 8-10" but should i get it?
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
F
Need body/paint shop in san jose area
  • FordFan
  • Nov 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 21, 2025
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
F
Black Headlight Area
  • frwgt350net
  • May 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Willybill32
