Bonehead mistake.....
  • Thread starter Thread starter mbsprinks281
  • Start date Start date Sep 27, 2007
mbsprinks281
58
Lockport, IL
Sep 27, 2007
  • Sep 27, 2007
So here we go............
A friend of mine just did a TrickFlow Upper half kit. Heads,cam,intake, 1.6 rockers, 30lb injectors, underdrives, flaming river manual rack. Smog pump and hardware, A/c and hardware, egr and hardware have all been removed. Pretty much all the things that can be removed have been. He has been messing with this car for months.
Now, when he goes to start it, its a real hard start. The fuel smell is very strong. I went to help him yesterday and found a few things......
The timing was off, I set it 10 degrees and re stabbed the distributor...
I reset the valve lash on all cylinders....
Good spark....
Good fuel pressure.....
Tried to start again.....same $hit. Ok......went thru all all the vacuum lines,no problems there......
Then I notice something.........
When he pulled the hard heater lines on the passenger side manifold, he plugged the engine temperature sensor hole in the manifold and left the sensor unplugged.........
DOOOOHHH!!!! Could this have caused the problem he's having????? The car runs but only over 1500 rpm's or else it dies......Plugs are DEEP BROWN almost black and it smells like its running pig rich.............
Please, tell this is the problem so I can get the new sensor and be his hero......
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 27, 2007
  • Sep 27, 2007
I would have to say yes. Get it all fixed up like Ford had it before you took it all apart and go from there.
mbsprinks281
58
Lockport, IL
Sep 27, 2007
  • Sep 27, 2007
Also, with 30lb injectors and stock computer tuning,is start up going to be a problem. Am I not going to be able to get this car running for him without a custom tune or what??
load71
68
  • Sep 27, 2007
Is the mass air calibraited for 30 lbs injectors? Also are any codes showing up?
mbsprinks281
58
Lockport, IL
Sep 27, 2007
  • Sep 27, 2007
Yes mass air is set for the injectors......codes are all egr, charcoal can codes......and this sensor
mbsprinks281
58
Lockport, IL
Sep 27, 2007
  • Sep 27, 2007
ttt
ninety15.0
1,336
  • Sep 27, 2007
Might have to turn the fuel pressure down a little bit. Those 30# are probably a little too big for his combo. I would try to drop the fuel pressure, clean the IAC, and re-set the base mechanical idle. start there.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 27, 2007
  • Sep 27, 2007
That was very likely the problem. Plug it up and start it.
The 30lb injectors can create to much cranking fuel, depending on the level of calibration. I still have mine set at the stock setting at 39psi with vacuum line off and engine warm/running.
Sicarius428
2,085
Sep 27, 2007
  • Sep 27, 2007
I was able to run my 19s with the TFS top end kit just fine. I went with 24s later because I got a good deal on them and figured later on down the line it would be useful. After the motor is warmed up does it still run like poorly?
Kevin
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Sep 27, 2007
#10
  • Sep 27, 2007
  • #10
make sure you have the H.O. firing order. the car will run on a non H.O. firing order. it will also run if you wire it clockwise too. (ask me how i know ) but it will mkae for a very HARD start and runs like crap.
M
Mike85000
65
#11
  • Sep 27, 2007
  • #11
ECT sensor plays a large role in the A/F ratio. Especialy on cold starts, if it thinks the engine is cold it will enrich the ratio. Is it throwing the ETC out of range code?
Get that **** plumbed back in, then report back.
mbsprinks281
58
Lockport, IL
Sep 27, 2007
#12
  • Sep 27, 2007
  • #12
Thanx guys..................that project is on hold until the new sensor fro 50 resto is delivered......
Mustang78
486
Aberdeen, WA
Sep 28, 2007
#13
  • Sep 28, 2007
  • #13
your local parts store should sell those..right?
mbsprinks281
58
Lockport, IL
Sep 28, 2007
#14
  • Sep 28, 2007
  • #14
Well, were getting the parts today so we shall see what happens....I'll keep ya'll posted....
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • dan50
  • Jul 18, 2026
dan50
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
