borgenson steering conversion with Z-bar
You are correct this is right from the web site
"Featuring the Borgeson integral power steering conversion box, complete power steering conversion kits include all necessary components to convert your classic Mustang to true modern power steering.
NOTE: Power conversion box will not fit with factory clutch linkage
All Steering Boxes have a 3yr. Warranty."
Does anyone need some new old stock Z-Bar parts?
According to te tech guy, I think his name is Gil, at Borgeson, it's close enough to fitting and they don't rule out that an imaginative soul might be able to mod things enough for it to work, but they don't make and did not engineer a mod. I say go hydraulic. Is your car a T5, top loader or a three speed? What year is your car and do you have power or manual brakes? Let us know. I may be able to point you in a fairly easy and inexpensive hydraulic direction.:D
HTH,
Gene
It will be a 5.0 with a T5 and the motor and trans are out so it's a good time to make mods. The pedals are also out of the car and so far I have manual brakes. Thanks
PS: I need to learn to put all pertinent info in my tech questions! thank you for your patience.
