boss 302 block
I find its crazy that noone has mentioned these motors are totally different from a production 302 block. A little history about this thing, they were produced for trans am racing and use canted valve 351 cleveland style head, they dont even use the inline valve head most 302's do. Ford used this setup to make horsepower at high rpm as most people know that type head is way too big for most street motors, they were prone to having very little low end torque, but with todays technology im sure you could piece together a great combo thats fairly street friendly. Maybe a stroker motor with a low gear would help the lack of low end torque, or a turboed/ blown motor combo would be wicked with this block. Just kinda a random rave i went on here, I was just reading all the posts and noone seemed to say nething about how these motors are made, just wanted to clear it up a little before someone went and dropped 1700 bucks on a motor that didnt suite their needs.
They are not selling a whole engine, it's just the block. The block has no affect on where the engine will make power, that's all in the combo. What you said about the heads on the old school Boss's may be true, I have no idea, but that would just be because of the h/c/i combo they used on the engine, not the block itself.
Ford is going to offer a Boss 331/347 stroker crate motor along with other Boss blocked crate engines sometime in 2007. This info was gleaned from fordracingparts.com, download 2007 engine catalog in .pdf format. I remember seeing on one of Ford's sites a new Boss 331 stroker crate motor for $10K.
The R302 is rated @ 1500hp, the A4 is 1200hp, Dart Sportmen 1200hp, Dart IE 2000hp, World Man of war 2000hp. Ford made it as strong as the R302 but also better. I have a R304ci longrod engine and I drove that thing on the streets of LA and never had a cooling issue.
Yes, I understand what your saying about the combo, but the block itself is setup for cleveland heads, and clevelands arent known for great low end power.
i think you might be a little confused, this boss302 is a totally new block, and totally seprate from the boss302 motors of 69/70. they share some of the same features, yes, but the new block is based more on the r302 than anything else, and should actually be considered an r302v2. it will accept a production rotating assembly (if anyone actually wanted to do that), as well as stock late model heads, cams, intakes, accesories, etc, as well as all the aftermarket stuff.
Even so, the production Boss 302 blocks can be used with normal Windsor heads with no issue. The difference was in the heads which had the right water passages and steam holes for a Windsor block.
